hey, why when i unplug my maya, my screen turns blue? i have vista.
geposted Mon 24 Dec 07 @ 4:48 pm
do you have the option to safely eject that card on your task bar? if so try to use this
the blue screen is the blue screen of death which ocurs when windows crashes
it might be a problem with the drivers try a reinstal of them
geposted Mon 24 Dec 07 @ 6:04 pm
As Sky mentions, it's not wise to just unplug USB devices. You should safely remove them via the USB Safely Remove Hardware utility or shut the system down before unplugging. And since you are asking about the Maya44 USB device you might get a better answer from their support site.
geposted Mon 24 Dec 07 @ 6:59 pm
because i dont have that icon to remove the usb, i turn my laptop off then i unplug it and then i turn it on. but why dont i have that icon?
geposted Tue 25 Dec 07 @ 2:20 pm
go to run and paste this in
RunDll32.exe shell32.dll,Control_RunDLL hotplug.dll
and the safely remove wizard will apear
you can aslo make this as a shortcut for future use :)
enjoy
enjoy
geposted Tue 25 Dec 07 @ 5:55 pm
awsommmmmmmmmmmmm, i cannt believe it.
tnx
tnx
geposted Wed 26 Dec 07 @ 1:46 am
You are most welcome , happy mixing. :)
geposted Wed 26 Dec 07 @ 3:40 pm
hey remember u gave this thing to me: runDll32.exe shell32.dll,Control_RunDLL hotplug.dll
it doesnt work anymore. and now i have the same problem, as soon as i unplug my maya my screen turns blue. what should i do? when i use this "runDll32.exe shell32.dll,Control_RunDLL hotplug.dll " it doesnt show anything.
tnx
tnx
geposted Sat 09 Feb 08 @ 11:06 am
I have the same problem; what I do is that I unistall after I use it, and whenever I want to use it again I need to install it
I know it sucks.
But thats the way that I am use to it.
I know it sucks.
geposted Wed 09 Apr 08 @ 1:14 am
a cheat for this is to go to device manager and simply disable the device before you remove it
Find it under sounds , game and audio controllers right click and choose disable hardware.
geposted Wed 09 Apr 08 @ 3:14 am
