Forum: Old versions
Topic: NEED HELP BEFORE NEW YEARS GIG
jkoongHome userMember since 2007
Hey all,
im not to sure why but when I'm running the program off time codes on one song i'll be able to scratch, move to different spot in the song, but when I load the next song I can't do anything except use the internal mixer. I usually have to reset the program to have my turntable working again but I can't be doing in the middle of my gig so anyone know how to solve this issue?
Thanks
DJK
geposted Mon 24 Dec 07 @ 11:55 pm
It's really not recommended to use the trial version (or crack version) at any gig. Regarding timecode the important thing to remember is to make sure your signal is at 100%. Also what type of soundcard are you using?
geposted Tue 25 Dec 07 @ 9:52 am
cstollPRO InfinityMember since 2004
Your best solution is to purchase the full version of the application.
http://www.virtualdj.com/buy/
As mentioned above - You chose to make a living at your own risk and results if you use the Trial Version or a Crack version. Sympathy and solutions will not be found here if you chose to use anything other than a Full Version LIVE.
geposted Tue 25 Dec 07 @ 10:06 am
