Secondary Gain Slider in menu (Soundcard/Timecode Config) to adjust the proper Input Gain when you play Real Vinyls. (timrvode bypass)
I saw that Timecode vinyl gain adjustment (using autoconfig) is a bit high (for normal sound) produciing a hiss noise when switching from Virtual to Real. Especially when playing easy listening songs or when the needle is on the start/silence groove. So I think there is a need to set a secondary gain for when you enable the Timecode_bypass funtion.
geposted Thu 27 Dec 07 @ 4:48 am
