The problems that occur when using ICDX with Cue,(buggin out after 45 minutes of mixing), do they occur when using ICDX with Serato? I'm hoping that it's a lot more stable.
Andy.
Andy.
geposted Fri 28 Dec 07 @ 1:33 pm
Not heard of such an issue.. Think iCDX got a firmware release btw.. that might fix stuff.
If it works with Serato, I dont know.. But you can ask at their forum... ;)
geposted Fri 28 Dec 07 @ 1:43 pm
Please provide some more info about the 'bugging out'.... what is happening?
I use one on a regular basis and don't have issues.
geposted Fri 28 Dec 07 @ 1:45 pm
I have used my iCDXs and mixed for five and six hours with no issues..what version of VDJ/CUE are you using?
geposted Fri 28 Dec 07 @ 2:02 pm
I've been on here before and there are people with the same issues that I'm having. For instance, when mixing with Cue and ICDX after about 30 to 45 minutes it may switch sides, go in reverse, stop altogether, not be able to make pitch adjustments and I would have to reboot every time. And yes you can use Serato with the ICDX in internal mode like you were using Cue. I just want to know if the same problems occur using Serato. Thanks.
Andy.
Andy.
geposted Sat 29 Dec 07 @ 2:16 pm
