So i was wondering if the needles that you use will make a differance in the quality you get out of a tcv setup
geposted Sat 29 Dec 07 @ 9:31 am
The quality of needles is quite important , as it ensures a good quality signal for the time-codes.
You can find some good recommended ones if you do a search.
http://www.virtualdj.com/forums/30/General_Discussion.html?search=tcv+needles
geposted Sat 29 Dec 07 @ 11:57 am
