So heres whats its set on!
Ok so heres my setup
Two Staton T60's and the hercules mdk console as my cross fader (for temp...also when i get a new crossfader how do i hook that up..a drawing be greatly appreciated)
So anyways sometimes when im spinnin tracks on my time coded vinyl and switchin back and fourth it happends...what i mean is sometimes even though the record starts to play the song wont play, so then when i click play on the mdk console the track plays and even though it shows im scartchin the record on the virtual dj display,,its not scratchin on the record, then i have to go back into my system config switch mdk console to asio driver then when that problem happends again i switch from asio to mdk!...can anyone give me a suggestion how to fix this!
geposted Sun 30 Dec 07 @ 11:50 pm
What version do you use?
Have you tried the steps here ?
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
geposted Mon 31 Dec 07 @ 6:26 am
Thank you that topic is right on the money and has a diagram and pictures for my questions, perfect!!
geposted Mon 31 Dec 07 @ 10:22 pm
Hi tekneek,
U need to upgrade to pro in order to use it fully as the djc edition only permits u for 5 mins of usage. Try download the demo first:) It werk for 20 days.
N if u like this software, do support its development by purchasing it. Thanks;)
PS: U can have a discount when u upgrade to pro as u own the djc edition.
geposted Wed 02 Jan 08 @ 2:53 am
