Quick question about the vinyls i have the software but i just love the feel of vinyls. I'm more of a hands on person so.... If i buy the vinyls how do they sync with my laptop and correspond with my turntables. I love the software very helpful i'm still buying vinyl gotta pay my dues. But any help is greatly appreciated.
geposted Tue 01 Jan 08 @ 8:31 pm
welcome , basically you need a dual stereo input card such as the maya 44 usb , the u46dj , or Virtual Vinyl
this allows the vinyl signal to get to the computer , basically the software listens for changes in the signal and reacts appropriately for example if you scratch the vinyl the mp3 will be scratched in exactly the same way, if you change the pitch the same is reflected in the software.
You can learn more , by going to the hardware page , http://www.virtualdj.com/products/hardware.html and by searching the forums.
http://www.virtualdj.com/forums/31/Hardware_Technical_Support.html?search=timecoded+vinyl
Hope that helps you.
geposted Wed 02 Jan 08 @ 7:14 am
