I've been having a lot of problems trying to get a timecode signal from my decks.
I've gone into the Audio Midi Setup and set Maya44 as the default output/input device.
I've turned up the volumes and tried different configs in the Maya44 Control Panel.
In Virtual DJ if I click TC and bypass the timecodes it plays, and I can control the sound through the mixer (crossfader,etc).
In Garage band, I can record from the device so I know the inputs are working.
Any advice would be much appreciated.
Thanks
Thanks
geposted Wed 02 Jan 08 @ 2:40 pm
Howdy you need to setup an aggregate Device for the maya follow the steps detailed in the mac manual ad-on.
http://www.virtualdj.com/forums/76062/MAC_Version_Technical_Support/Virtual_DJ___Cue_Manual_Ad-on_For_MAC_(4_3__5_0_BETA).html
Please add your serial as this beta version is available to register pro users only.
geposted Wed 02 Jan 08 @ 6:36 pm
