I just purchased a Plextor PX-716UF and the CDG Ripper from Tricersoft . It took a while to get the software to recognize the burnner but I got everthing to work . VirtualDj works perfectly playing the CDG files. So since I have dual monitor support on my HP laptop I pluged in my 12 inch LCD and it shows the graphics perfectly . This is exactly what the doctor ordered . I did not have to modify the files either.
geposted Mon 22 Nov 04 @ 4:53 pm
Wow... That is one side of VDJ that I have been wanting to try. You had to use a plugin for that didn't you?
The video card I am thinking of getting will have a video out which should work like a dual head card (I'm hoping since I haven't tried it. ). It is the Leadtek nVIDIA GeForce FX 5700.
Killabee44
Killabee44
geposted Tue 23 Nov 04 @ 12:29 am
VirtualDj already has the plugin. All you have to do is activate it through your effects section.
geposted Tue 23 Nov 04 @ 6:05 am
