I can confirm there does seem to be a slight drift between the decks as reported, but no idea as to why yet!
geposted Thu 11 Sep 08 @ 1:29 pm
OK cause found, I'll have this fixed this weekend for sure :)
Another bug found - it's the cause of pauljohns problem - something is causing one of the gui config settings to be changed...
geposted Thu 11 Sep 08 @ 1:39 pm
Both things are now fixed, but I have to run to work now, and it needs compiling on the Mac.
I'll see if I can get time after work tonight, but no promises...
geposted Thu 11 Sep 08 @ 1:46 pm
The sync button does not flash to the beat I can not remember if it did this before or not ,
but if not can this be added ?
geposted Thu 11 Sep 08 @ 6:47 pm
its supposed to :)
geposted Fri 12 Sep 08 @ 10:21 am
It did... it should flash when all the other lights flash?
geposted Fri 12 Sep 08 @ 10:52 am
I am talking about when its not in Christmas mode
geposted Fri 12 Sep 08 @ 5:07 pm
Very odd. Whats your beat sensitivity set to?
geposted Fri 12 Sep 08 @ 5:31 pm
It will work for a min then stop. I have it set half way
geposted Fri 12 Sep 08 @ 10:33 pm
Even odder. Will have a play this afternoon :)
geposted Sat 13 Sep 08 @ 7:16 am
Hi Scott , if you have a moment look at this you tube link....very interesting
Could we also do this with VDJ ??
http://www.youtube.com/watch?v=acm9t8Y7--w&feature=related
Regards Paul
Regards Paul
geposted Mon 15 Sep 08 @ 3:05 am
Which bit are you referring to? The XY pad control?
geposted Mon 15 Sep 08 @ 5:51 am
hi Scott , yes exactly the touch pad/mouse assigned to a eg. delay with bpm controllable.is that already possible or will it be as in the video?
thanks P.
thanks P.
geposted Mon 15 Sep 08 @ 12:23 pm
Assuming the XY touchpad has been fixed (it didn't work in earlier VDJ versions) then I can assign the touchpad to control two effect sliders - one left-right, and one up-down - each controlling a slider/pot in the currently selected effect...
geposted Mon 15 Sep 08 @ 4:16 pm
So , taking one step at a time how can we find out if the touch pad has been fixed ?
geposted Mon 15 Sep 08 @ 4:48 pm
I'll know when I go have a play :)
geposted Mon 15 Sep 08 @ 6:21 pm
Implemented :)
geposted Mon 15 Sep 08 @ 7:30 pm
OK, what I have done:
Touchpad X controls the current effect slider 1 on currently selected deck
Touchpad Y controls the current effect slider 2 on currently selected deck
Touchpad button 1 controls current effect button 1 on currently selected deck
Touchpad button 2 controls current effect button 2 on currently selected deck
Shift + Touchpad button 1 selects deck 1, and activates the currently selected effect
Shift + Touchpad button 2 selects deck 2, and activates the currently selected effect
How does that sound?
I've fixed the drifting issue, and a problem with the beat detection slider too...
Once I get the OK on the above, I'll consider releasing a new version, unless anyone has any other requests they would like to put in... :)
Regards,
Scott
Regards,
Scott
geposted Mon 15 Sep 08 @ 7:49 pm
Oh, and at someones request I've just added 2-stage warning flashing of the progress meter when nearing the end of a track too :)
geposted Mon 15 Sep 08 @ 7:58 pm
Well I've done a bit of testing, and on this version I cannot get xmas tree mode to go crazy, and the sync light definately flashes whether xmas tree mode is on or not!
geposted Mon 15 Sep 08 @ 9:38 pm
