How about ONE of TWO options or BOTH???
1) To have a file appear a specified color (i.e. red) for a specified amount of time (i.e. 30 days) after adding it to the library.
I can't tell you how many time I create folder after folder simply named "NEW" or "NEWER" just to keep my hot files easily accessible!!!
2) Maybe just give the option to color code files PERIOD!
This way I could just color code files a variety of colors that would mean something to me and they would stay color coded till I decided otherwise!
***AND as a BONUS.. maybe a way to "sort by color code just so I could view my coded files without browsing through the entire folder"***
I think this could be done in a software upgrade or maybe more easily as a plugin!!
DAMN I wish I knew how to make a plugin.. I would be posting this in the download section instead of the wishlist forum :-(
geposted Fri 04 Jan 08 @ 3:02 pm
alternatively you could create a filter folder
filter: "days since firstseen < 30"
with this filter songs first seen within the last 30 days will be displayed.. you can change the 30 to any number of days you want.. 60, 90, 91,93, etc.
DJ Shahar
www.djshahar.com
DJ Shahar
www.djshahar.com
geposted Fri 04 Jan 08 @ 9:23 pm
