Hello !
I recently acquired a Sound Blaster External 24btis live! sound card, which I was told would work with a headset on Virtual Dj
Yet I don't know how to plug it in to make it work.
My setup is like this :
Sound system = Sub woofer + 2 speakers, left and right + a little box that cotnrols the volume on the whole thing and sub and treble.
Sound system plugged into Sound car "front" plug with a green cable coming from the little box.
Where should I pluf the headset and how should I configure VDJ ?
geposted Sat 05 Jan 08 @ 5:52 am
ephem
try this
open up vdj
go to config
open up sound set up > choose
outputs > headphones
sound cards > 2 cards
output channels 1ts card (ext) channel 1 on mixer, 2nd card (lappy or pc card) channel 2 on mixer (or directly plug your headphones to the external output on your pc/lappy)
hope that helps
Tayla
try this
open up vdj
go to config
hope that helps
Tayla
geposted Sat 05 Jan 08 @ 6:20 am
Hmmm
I don't have all those options :/
I have "Sound card" in my config, but not sound setup and I can't choose outputs, 2 cards etc.
Is it bevcause I'm not using the pro version of VDJ?
*edt* : If I scroll down yeah I do have options for 2 cards, do I set one to the external and then plug in my headset on the internal?
Is there a way to just use my external Sound card?
geposted Sat 05 Jan 08 @ 6:30 am
ephem
you must set for 2 cards if you want to use your headphones, how many outputs do you have on your external card, if only two just follow the above
Tayla
hope that helps
Tayla
hope that helps
geposted Sat 05 Jan 08 @ 6:43 am
I have more than 2 inputs on my external sound card.
I have :
- Front input
- Rear input
- Line in
- phones input
- spdif input
- c/sub input
I have :
- Front input
- Rear input
- Line in
- phones input
- spdif input
- c/sub input
geposted Sat 05 Jan 08 @ 6:56 am
ephem
not familiar with this card is it the one that has usb connection and three mini jack connectors green orange and black?
its not inputs we need its output side
geposted Sat 05 Jan 08 @ 7:25 am
if anyone is familiar with this one please feel free to step in on this one we both be grateful lol
Tayla
Tayla
geposted Sat 05 Jan 08 @ 7:28 am
My external sound card is this one :
http://www.soundblaster.com/products/product.asp?category=1&subcategory=206&product=10702
The back looks like this :
http://www.bhphotovideo.com/images/items/437709.jpg
I'll try find a better photo
*edit* : Best photo
http://img.ktr.pl/m/muzsblive24ext/db.jpg
*edit again* : Sorry on my other post I wrote input instead of output >_<
*edit* : Best photo
hi ephem, sorry bout' delay popping in and out of house all day
try this in config set up
output > 3 lines
Soundcards > 6.1
then hook up to mixer as described in output channels
output > 3 lines
Soundcards > 6.1
geposted Sat 05 Jan 08 @ 8:24 am
I don't have a mixer, just my PC, sound card, VDJ, sound system and headset =p
geposted Sat 05 Jan 08 @ 9:04 am
sorry been away again
could you try as above settings but one and two channells go to your speakers headphones to its socket, i haven't got your skin but at the top is there a slider with h/phones icon use that to cue up, hopefully ephem we may hit on, try different combinations and see how we go...
Tayla
Tayla
geposted Sat 05 Jan 08 @ 12:46 pm
Well, I've tried loads of things, including stereo spliter, 4.1 sound card and 2 sound cards yet it never seems to work.
Maybe I'm not doing it right?
Do you have MSN Messenger ? Would be a lot easier to actually resolve this.
What would be the msot logical solution would be the 4.1 mode and having the headseat pluged into the "rear" spot and the sound system in the "front" spot.
geposted Sun 06 Jan 08 @ 4:24 am
hi ephem
sorry in & out all day again, give it ago wont do any harm sorry i have'nt been much help to you on this hopefully an angel is looking over our shoulders and can step in, i will keep trying until we can get this damm thing going for you its just i have'nt got the version your using mate so basically i'm running blind here
Tayla
Tayla
geposted Sun 06 Jan 08 @ 11:15 am
I found a screenshot of the Sound setup on the pro version, it looks a lot easier to get working than on the home edition.
But now I've bought this one I don't particularly want to buy the pro version as well :/
geposted Sun 06 Jan 08 @ 2:05 pm
Anyone else?
geposted Fri 11 Jan 08 @ 10:56 am
Finally got it working, used the 2 sound card system and plugged it all in a different way from the one I had been trying (inversed it)
Thanks a lot =]
Thanks a lot =]
geposted Sun 13 Jan 08 @ 4:50 am
there are differnt holes in your soundcard, blue/green/black/red I believe.
Black and green are both Output. Try put your headset in the green one, while only having the surround plug in the black one.
green: output 1
black: output 2
green: output 1
black: output 2
geposted Mon 14 Jan 08 @ 6:04 am
