I currently use A hercules MK2, & SL1 As The Sound Card, I have great results but I want a better controler(i have worn throught two in the last year), but i don't want to go timecode. I was thinking of a cortex dmix 600, any feed back or other suggestions.
Thanks Jay
Thanks Jay
geposted Sat 05 Jan 08 @ 2:40 pm
it depends on your mixing needs and style, Numark has the DMC2 and total control, vestax has o good one too , then is the high end a&h xone3d, so as long as you are using the SL1 as a sound card most of this will work, but for the DMC2 you will need a mixer too or just use the fader buttons on it
geposted Sat 05 Jan 08 @ 3:35 pm
i use the numark dmc2. it does what i need it to do.
play(stutter), pause, cue, scratch, search, time
geposted Sat 12 Jan 08 @ 6:43 pm
xone:3d, xone:3d! :-) Cant stop talking about it, it rocks. more controls, anything you want. More total control than the total control ;-)
geposted Sat 12 Jan 08 @ 9:21 pm
