Anybody have any ideas why all of a sudden timecode signals will flucuate and sometimes drop to zero. It is happening all the time.
it wil stay at zero for a few seconds and then jump to 68% then to %100 back to %50 and then to zero. It is happening on both decks.
I have a mac book with 2.2 ghz and 2.5 GB ram. I use VV.
Any thoughts would be great. I know its beta and I am being patient but... my friends serato.. it seems to not have any of these issues I constantly have.
I dont care about video and all that, I just want to focus on mixing not on trying to make this software work properly.
Another thing that was happening last night was when i used command S as a keyboard shortcut, it would stop the song!!! (usually it would sync)
thanks
thanks
geposted Sat 05 Jan 08 @ 3:40 pm
Do you have the white or black macbook?
Which usb port do you use? if you t on the right side make sure you update your apple system software as there was found to be a bug with this port.
What Performance options do you have set try setting latency to auto and un-ticking safe and over-clock.
Could you please take a screenshot of the time-code Con-fig screen and upload it to a site like tinypic.com and send it to me a link via private message.
Thank you
Thank you
geposted Sat 05 Jan 08 @ 5:42 pm
Thanks Skyfxl,
I have set latency to auto and unchecked clear sound with huge improvements. Time Code signal is more consistent and I am not experiencing the auto config and start
up crashes you were helping me with on a different thread. There are good days and bad. Today has been good. Thanks.
I have a mac book (black) w leopard and 2.5 ram
Any other suggestions for set up and configuration, I am surprised of the difference in stability after making these few changes that you suggested...
Cheers,
R
Cheers,
R
geposted Sun 06 Jan 08 @ 4:45 pm
