Hi All
I've just downloaded the demo version of the VirtualDJ software. The software works great but when I use the DMC-1 controller in the demoversion, the controller hangs quite often, besides I can't get it to control the song list. Anyone experienced the same ?? Anyone using the VirtualDJ and the DMC-1 controller together ???
geposted Tue 23 Nov 04 @ 2:09 pm
hi
a mapper for dmc/dac is looked into by dev team, and might be around very soon ;)
geposted Tue 23 Nov 04 @ 2:13 pm
Do you have the upgrade chip for your dmc1?? If you hold down load and work the jogs it will control the songlist.
geposted Tue 23 Nov 04 @ 4:56 pm
No I dont have the Upgrade chip .... does it make any difference in VirtualDJ ?
geposted Tue 23 Nov 04 @ 5:36 pm
Yes you need it to unlock the DMC1 to work with other programs
www.gizmolabs.net
www.gizmolabs.net
geposted Tue 23 Nov 04 @ 6:01 pm
