Hi again
Why can't I play my songs I bought in the Itunes store? they are m4p.
Which skin do you recommend for latest macbook? I still have some space left and right when i put big screen on.
Thanx
Thanx
geposted Wed 09 Jan 08 @ 7:34 am
This is because itunes only allows their music to be played in itunes or on an ipod.
Good skin for a macbook is the Vmix single instance 1280 x 800 , if you have acess to a pc you can install the skins then extract the skins as zips and copy them to your mac , if not pm me with your email and i will send you the zip of the skin.
geposted Wed 09 Jan 08 @ 12:07 pm
