Hey Guys,
I have bought a Numark Total Control and there is Numark CUE with it.
So i load a track on one deck and start it. When i now move the Treble/Mid/Bass Buttons there is a distracting noise like a quiet humming.
I tested a lot like changing the soundsystem, using another sound card and even plug off the DJ Controller. No solution...
So i guess it has something today with the Software itself. This was confirmed when I installed the enclosed TRAKTOR 3 LE. No Problems there, but its ugly :)
You have any idea which settings to change to avoid that noise? I use the standard settings at the moment.
THX in advance! Greetz, Jack
geposted Fri 11 Jan 08 @ 4:35 am
What is your machine specification , what soundcard do you use?
geposted Fri 11 Jan 08 @ 1:27 pm
I found the solution myself...thx. "Safemode" in the Performance Options was the problem...
geposted Thu 17 Jan 08 @ 3:15 am
