Dear All,
I have a question about connection my mixer to my PC.
here is the situation.
i have a regular onboard sound card with 3 outputs line-out / line-in/ mic.
Now i would like to connect my 2 chanel mixer with virtual DJ and have the abillity to record everything that i do on the mixer.
i really have no idea how to make the connections between the two devices.
can someone please give some adivce hw to connect the devices.
i prefer some drawings to get the brightest view :)
thanks in advance,
Kind regards Danny
thanks in advance,
Kind regards Danny
geposted Fri 11 Jan 08 @ 1:12 pm
Hi there you require a card like the maya 44 usb , mk2 dj console , vv or u46 dj to allow you to do this
you can then record the track via the line in of the internal card.
geposted Fri 11 Jan 08 @ 1:34 pm
so the situation that i have right now is not going to work?
to bad :(
and do you besides your advice think a secondary soundcard will work?
thanks!
to bad :(
thanks!
geposted Sun 13 Jan 08 @ 6:26 am
didnt he just say that he has 3 outputs (im assuming stereo) and line-in? thus i will assume this means he has a 5.1 surround card...
yes, it will work for you. put vdj into 4.1 surround mode.
you will need three 1/8" jack (headphone) to RCA adaptors and 3 stereo RCA cables
connect one adaptor and RCA cable from soundcard-FRONT to channel 1 of mixer
connect one adaptor and RCA cable from soundcard-REAR to channel 2 of mixer
connect one adaptor and RCA cable from mixer MASTER OUT to laptop-LINE-IN
in vdj, in the recording section, depending if you want to broadcast or just record, set the input to the soundcard LINE-IN...
And thats all it takes.... There is actually a guide with an image somewhere in this forum.. not sure where though.
geposted Sun 13 Jan 08 @ 9:16 am
whoops, sorry i may have misread that.
did you say you have
a) 3 outputs/line-out/line-in/mic
b) 3 outputs: line-out/line-in/mic
the first one being 3 + 1 + 1 + 1... I think you mean b), so disregard my post, sky is correct.
never tried using a secondary sound card. the way i look at it, you need to buy another one how, and even for a cheap price you can still get one sound card that does it all for you...
geposted Sun 13 Jan 08 @ 9:17 am
yes your answer b was correct.
sorry for the confusion line-ou/line-in/mic.
this are the available connections.
thanks for the responses i gues i can use this in the future :)
geposted Mon 14 Jan 08 @ 4:41 am
Do you have firewire and are you using a tower or a laptop?
USB is WAY over priced right now for these A/D audio interfaces. Firewire is a bit cheaper but PCI (short slot) is the best solution if available. I picked up a Maya 44 PCI for $41 off of eBay just last night.
Two sound cards do work but they most likely won't be true ASIO and they will have latency. I remember YEARS ago that was the only way to make it work, two sound cards.
If you must go the 2 x Sound card route go to eBay and get yourself a USB interface. they will cost you $10 with shipping. They only have a line out and a mic in and they arn't the best but until you are ready to make the investment that is a simple and cheap solution. Let's face it, when a A/D card casts as much as a new CDX it would be kinda silly to pass up on true hardware. A CD-MP3 system will work better than all software simply because you won't need a monitor lol
geposted Mon 14 Jan 08 @ 8:16 am
i'm working on a desktop without firewire.
but can you give me link with the product that you advice me.
geposted Tue 15 Jan 08 @ 2:58 pm
