Forum: Old versions
Topic: virtual dj with numark usb tt
would i be able to use the timecode vinyls thru my laptop using the Numark TTUSB turntables alone or do i need more equipment? i would like to know b4 i purchase them.
and na i dont anna buy anything extra that i dont need
geposted Fri 11 Jan 08 @ 4:06 pm
You will require a soundcard with two stereo inputs like the maya 44 or the mk2 or vv or u46djmk2.
all these however look like analog to digital (since im talking bout usb turntables)
will these specific soundcards work with them...or will i end up having to use usb ports on my pc and no luck?
The reviews on the usb turntables are not terrible but, Skyfxl is correct. To truly unlock the potential of time coeds and VDJ your better off going regular turntables with a good quality ASIO soundcard.
Actually dude these USB tables are not designed for Digital DJ'ing
They are for recording your Records to MP3
To DJ with turntables you will need - regular DJ tables, an ASIO soundcard with 4 input channels and 4 output channels.
Plus a legit copy of VDJ cause cracked versions have trouble with white noise.
You can use the Txx as a normal turntable too so just ingore the usb ports in this case and use one of those interfaces with the phono connections.
