Forum: Old versions
Topic: Stanton C.314 HELP
Hello,
I Just Bought a stanton c.314 , I only bought one because i dont have the money. I already have the Hercules Dj Console mk2. I have vdj pro already. I pluged my stanton in the inputs 1/2 of my DJC MK2. And I changed the configuration of the program to single timecode, so then i can control the both sides ( A and B ). It worked. But I am having some litlle problems. I burned on a cd , the timecode, the consumer grade , and the pro grade and im still having some problems :
-When I switch the pitch to key lock and i move it up and down (on the stanton ) ,it does a weird noise.
-None of the effects are working, when i press by example the phase or echo button, it will do a weird noise too.
Maybe its the timecoded cds ?? I dont know. But can you help fix this problem ?
Thank you
geposted Sat 12 Jan 08 @ 10:20 am
Don't use the pitch lock on the player - use it In VDJ
Same goes for Effects - Use the one in VDJ - only use the Player for controlling mp3 manipulation.
geposted Sat 12 Jan 08 @ 10:23 am
