Forum: Old versions
Topic: Some mp3s will load, some won't
same with m4as. Some will load and work fine, some I'll get an error. Is this a codec problem?
I had matroska codec pack, then installed k-lite instead, and I'm getting the same problem.
geposted Sun 13 Jan 08 @ 12:50 am
Where did you source these mp3s from , itunes?
Yeah. I figured that out last night. Songs work fine if I get them from the MP3 folder they are sorted to.
