Hi,
I'd like to play time-coded vinyls. Could I do this with this setup:
* laptop
* Maya 44 USB
* turntable
* http://www.behringer.com/VMX200/index.cfm?lang=eng
So i'd like to scrath an mp3 on one deck and just play regularly on the other.
Thanks in advance
* laptop
* Maya 44 USB
* turntable
Thanks in advance
geposted Mon 14 Jan 08 @ 3:43 pm
If you want to use the maya you will need to upgrade to professional edition at a
discount.
discount.
geposted Mon 14 Jan 08 @ 4:39 pm
Yes but as long as we are talking about required hardware that would be enough? If so, shouldn't turntables be plugged to phono inputs instead of line inputs, does that really work? And where do I attach the grounding cables?
Thanks
Thanks
geposted Tue 15 Jan 08 @ 12:48 am
the home edition wont let you use that card for timecode
if you own the mk2 console you can use that if you want to use a pro grade card like the maya you need pro.
geposted Tue 15 Jan 08 @ 7:39 am
