i am trying the vd5 trial on my macbook pro, seemed to be working fine then i put leopard on it.
last time i used program it was in full screen mode) but since leopard it always opens as full screen and the top of the vd screen is missing (its higher up the page than my screen will see) so i can't minimise it or access config etc.
any ideas what to do?
geposted Wed 16 Jan 08 @ 8:24 am
There is no trial of the mac version , if you use an old unoffical version it will not work well if you like this program please support it by purchasing a full copy , then you will have acess to the latest updates in the download center to install.
Apple + O should bring up the options screen for you so you can change to a better skin for your screen.
Hope to see you as a pro user soon
geposted Wed 16 Jan 08 @ 10:12 am
