While playing vdj the songs randomly pause for a second or two. I'm running VDJ on Window's Vista with 140gig hard drive. Any idea why this is happening.
geposted Wed 16 Jan 08 @ 9:51 pm
scan lots of posts on skipping. Tell us more about your configuration, video card, sound card, memory, pc, ;laptop, os, version vdj etc
geposted Wed 16 Jan 08 @ 10:22 pm
Here's more on my PC specs:
Dell Vostro 1400, Intel Core 2 Duo, 1.6ghz, 800Mhz FSB
3GB, DDR2, 667MHz 2 DIMM
128MB nVidia GeForce 8400M GS Graphic Card
160G 5400RPM SATA Hard Drive
Genuine Windows Vista Business
Integrated High Definition Audio 2.0 / Numark IO sound driver
VDJ 5.0 rev 6
Thanks, ariwood
VDJ 5.0 rev 6
Thanks, ariwood
geposted Thu 17 Jan 08 @ 8:55 am
Disable any unuseful feature in vista n at setting, click safe mode n overclock n set latency to auto n set to fastest. Did that help?
geposted Thu 17 Jan 08 @ 2:27 pm
I'm not sure where you are directing me to go. Should I be looking at the start-up menu or reboot my computer then open in safe mode then go into the start-up menu?
geposted Thu 17 Jan 08 @ 2:43 pm
hehe.. sorry if that confuse u
in ur cue le settings at performances try click safe mode n overclock n set performance to fastest;)
n also disable ur aero or other thingy that not important in vista.
(sorry i use osx n xp but try the first options first.. )
geposted Thu 17 Jan 08 @ 2:57 pm
Music continues to skip while in play. could it be that DJio soundcard is not compatiable with Vista. This doesn't happen on XP.
geposted Thu 17 Jan 08 @ 9:02 pm
the djio should be compatible with vista too afaik. try to use the lappy sound card n see if that problem still persist.Hope somebody with vista n djio could comfirm this. meanwhile have u update all ur drivers n directx?
geposted Thu 17 Jan 08 @ 10:17 pm
