i would like to know what is the best between dj console mk2 and dxm01 usb ?
both are mixer , the only difference is dxm01 doesnt control the turnatble ( play cue effect etc ...)
but if i use icdx like controler with dxm01 is that configuration (icdx + dxm01 usb ) equivalent as dj console mk2 ???
thanks for all !
best regards
Dj KinG
thanks for all !
best regards
Dj KinG
geposted Thu 17 Jan 08 @ 1:42 am
i use the mk2 with an external mixer i love it couldnt ask for any better i also use tcv and i mix video and audio flawlesly the only ishew i have is the jog wheels are alittle close to the fader but i use external witch i thought it was a good way to eliminate my crosfader problem
geposted Fri 18 Jan 08 @ 8:49 pm
