Forum: Music discussion
Topic: master tempo?
dj1nabeHome userMember since 2008
how to set the master tempo of voice in bpm i mean i mix a song example: deck A 100bpm deck B 120bpm so i adjust the bpm to match my mix but the vocals and beat is change i mean when i adjust to low the voice is so slow and when i adjust to high the voice is like a chipmunks what can i do to match the bpm without changing their tempo or vocals/beat hope your help guys
geposted Sat 19 Jan 08 @ 2:43 am
Paz75PRO InfinityMember since 2006
press keylock
geposted Sat 19 Jan 08 @ 8:30 pm
Go to config, FAME Settings, and enable Master Tempo
geposted Sat 19 Jan 08 @ 9:58 pm
thanks for this guys!!!!!
geposted Sun 20 Jan 08 @ 12:58 am
tsybooHome userMember since 2007
Ez meg mi? Nem ertem mi ez a letöltesi cuccos. miert van ez igy . ehh
geposted Fri 22 Feb 08 @ 5:57 am
szal nem ertem miert kell irogatnom ahhoz hogy le tudjakl szedni vmit
geposted Fri 22 Feb 08 @ 5:58 am
remon4Home userMember since 2008
U cant do this without pro version I think?
geposted Wed 12 Mar 08 @ 9:27 am
Where is the master tempo? (sorry new user here)
geposted Sun 13 Nov 11 @ 12:58 pm
Hi, how can I set tempo and not pith on my RMX or pro version?
geposted Thu 28 Feb 13 @ 9:36 pm
On the default VirtualDJ v7 skin, click on the padlock icon next to the pitch slider to enable key lock on that deck. For further information, please read the VirtualDJ user manual: http://www.virtualdj.com/wiki/PDFManuals.html
We also recommend registering your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html so that you can retrieve it in future as well as download the latest and future versions of the software from the Download Center: http://www.virtualdj.com/download/updates.html
geposted Fri 01 Mar 13 @ 4:27 am
In Virtual DJ Pro I can't find the button to set the master tempo. In Virtual DJ LE it used to sit just next to the BPM number. How do I set one as the master tempo?
Also, after fiddling with my settings, my BPMs are now stuck on both decks and I can't figure out how to unstick them.
Help?
geposted Wed 13 Mar 13 @ 9:03 am
geposted Wed 13 Mar 13 @ 9:09 am
