Forum: Wishes and new features
Topic: Pioneer MEP 7000 & SEP-C1
heres some eye candy ... http://www.dogsonacid.com/showthread.php?threadid=551284&cache=2
heres my question.. will there be an update to use this controller / interface with vdj .. i mean a less capable software is mentioned " No names" and if im right you guys should support it in ur next update.. i currently use a set of cmx3000 decks with timecode cd's and a maya 44. if i use this unit as far as im concerned my dj life can get no-better...
any thoughts idea's id be happy to know
geposted Sat 19 Jan 08 @ 6:28 pm
Paz75PRO InfinityMember since 2006
might not need an update? it supports midi via usb so unless they mucked about with that support, it should probably work using the standard midi-remote capabilities of vdj?
geposted Sun 20 Jan 08 @ 5:38 am
