I first started having this problem on my Audigy 2 ZS pcmcia sound card.
Audigy problem... I have it set up for Front / Rear = Main / Headphone output. Now it's not seperating the outputs and I'm getting both Main & Headphone in the Front output. I've reinstalled the Audigy drivers several times and it used to fix it but now it doesn't. This is my back up card and I'd really like it to work hehe. I also have U46DJ but these problems started before I installed it on my laptop.
can anyone help?
Thanks!
Jeremy
geposted Mon 21 Jan 08 @ 10:22 am
I used to have Audigy 2 on my old system. As I remember, there is an option in audigy
drivers itself under output settings (where you choose number of speakers: headphone,
stereo, 2.1, quadro, 5.1, ...) where it duplicates the front signal to rear when using
only stereo signal on a Pc (or maybe under EAX options). Hope you'll find it, I don't
have my old setup here to check.
geposted Mon 21 Jan 08 @ 1:05 pm
PROBLEM SOLVED
I'm a tard hehe, apparently the Crossfader option had been disabled some how - so now it's fixed hehe. no clue how it happened but just happy to have my system running again :)
thanks!
Jeremy
thanks!
Jeremy
geposted Wed 23 Jan 08 @ 10:01 am
