Up until 4 days ago I could mix with console, no problem. I pushed the headphones button and heard what song I would mix next without hearing it on the main mix. For some reason what happens now is the exact opposite. I hear the echo of the monitored track in the main mix. My sound card is a Soundblaster Audigy.If possible please help because it has started getting on my nerves for starters and secondly I have to mix on a party on Friday.
geposted Tue 22 Jan 08 @ 2:49 pm
this sounds like a common problem that people have with timecodes. check to see if there is a control panel for the soundcard alone. in that control panel, there is usually a monitor button or level which allows the outputs to be fed through other outputs. i have the same thing on my m-audio control panel and it needs to be turned off.
geposted Tue 22 Jan 08 @ 8:28 pm
