Forum: Greek Forum
Topic: vdj 2.06 - Page: 1
gia osous den to phran xampari :)
2004-11-26
New software:
ripvinyl: easily make mp3 from your vinyls (can record several discs at the same time)
New features:
"Suggestion Box" folder gives a smart suggestion-list of music to play next
can read itunes, atrac (sony) and flac files if proper WMP codecs are installed
sound quality and responsiveness improved in low-latency timecode mode
DMC1/DAC2 mapper (via custom dll)
new right-click menu: add to search database, remove from search database
playlist total time displayed
automatically mute monitor levels with MAYA soundcards
new fame option: smart auto-bpm
faster search and sort in database
new action: "goto_last_folder"
new right-click menu: go to folder
new right-click menu: add playlist to history
can load .VDJ file on a desk
Bugs Corrected:
right-click menu actions (rename, move, delete, etc...) also change the database
incorect .CUE times in burn mode
high CPU usage in "load from disc" mode
cue points direction in inverted-scroll mode
auto pitch-reset
beatlock disengage on load disengages both decks
long 22Khz wav in sample slots
cue action on DMC1/DAC2
jingle-samples in lowlatency timecode mode
search comments in database
geposted Sat 27 Nov 04 @ 7:46 pm
To pirame! To pirame! :-))
Eisai kala file mou?
geposted Mon 29 Nov 04 @ 8:10 pm
mia xara :) perimenw na feroun to xp10 gia testing ;)
geposted Mon 29 Nov 04 @ 10:02 pm
TrNxHome userMember since 2005
geia sas ithela na mathw pote tha bgei h ekdosi tou virtualdj 2.06???
geposted Thu 10 Mar 05 @ 8:48 am
PANOSVPRO InfinityMember since 2007
h ekdosi paizei apo ton noembrio...oxi se demo omws...mexri 2.05
geposted Thu 10 Mar 05 @ 9:56 am
modified by dimitris_tsanak
geposted Mon 28 Mar 05 @ 2:32 pm
gia autou tou eidous ta problhmata xrhsimopoihse to support tha sou apanthsw apo ekei.
ekana kai edit to post sou
geposted Mon 28 Mar 05 @ 2:36 pm
ok se euxaristo litourgise to phre to programa
geposted Mon 28 Mar 05 @ 2:48 pm
enjoy:)
geposted Mon 28 Mar 05 @ 2:54 pm
dj mixpit - gia olous poy theloun na akousoun to programa mou live me to kainourgio mou 2.06 virtual dj
syntonistite sto ORANGE 93,2 FM kathe paraskeyh 22.00-01.00 kai kathe sabbato 21.00-00.00 to brady
NON STOP MIX (me ellhnika kai ksena).kali akroash.
kai to site www.orange932.fm
geposted Mon 28 Mar 05 @ 3:15 pm
tha htan pollu kalo an mporouses na bgaleis mia foto apo to setup tou vdj sto orange kai na mou th steileis sto dimitris@virtualdj.com gia na thn balw sto forum.
geposted Mon 28 Mar 05 @ 5:03 pm
gia dimitri tsanak : ena mikro problima exo tora me ta akoustika ti prepei na rhythmiso gia na akouo sta akoustika to deytero komati ?
mixalis
geposted Mon 28 Mar 05 @ 5:22 pm
auta einai....kai vdj ston orange....theloume photos!!!!
geposted Mon 28 Mar 05 @ 5:24 pm
mpes sto conf panel kai epele3e to setting analoga me to pws theleis na bgaleis to hxo.Prepei na exeis karta hxou pou uposthrizei duo e3odous gia na mporeseis na exeis full stereo preview
des to parakatw link pou einai kai optika to conf panel sou
http://atomixmp3.online.fr/config/
geposted Mon 28 Mar 05 @ 5:58 pm
gia dimitri tsanak : otan epilego SB LIVE AUDIO (B400) den akouo sta akoustika kai otan epilego hercules dj console mou bgazi "error in the sound driver of direct x" ti prepei na kano?
(shmiosi oti me to vdj 1.09 akouga sta akoustika kai me hdj 2005 drivers epaize h eksodos ths hdj console kai me to prasino fvtaki akouga sta akoustika) mhpos ftaiei to neo driver mhpos na to bgalo kai na balo to palio.
se exo zalisi ligo isos.........eyxaristo prokatobolika gia thn bohtheia mixalis.
geposted Mon 28 Mar 05 @ 6:21 pm
Oso gia to "error in the sound driver x" Shmainei oti thn teleutaia fora poy eixes doylepsei me to VDJ htan syndedemenh h consola. eno tora logika den prepei na thn exeis syndedemenh, opote ayto (VDJ) prospathi na thn brei giayto!! Den exeis problhma pantos oso gia ayto!!
By the way, ORANGE FM?? lol diashmo to VDJ. Steile fotos!!
geposted Mon 28 Mar 05 @ 6:34 pm
Antigrafw apo to
http://www.virtualdj.com/forum/display.html?topic=7731&page=1
Hi all,
We have tested the Virtual DJ full version 2.05 and our latest ASIO drivers available on the web.
Here are the results we found :
1- If you directly select the ASIO mode for DJ Console then launch Virtual DJ, you have this "DirectX..." error.
2- If you disable the ASIO mode in the DJ Console control panel and then launch Virtual DJ you are able to use Virtual DJ in non asio mode.
From there if you switch the DJ Console in ASIO mode and then select the ASIO config in the Virtual DJ panel and then choose Hercules DJ Console ASIO, there is a Virtual DJ crash !
3- We figure out a way to make it work in ASIO mode :
- Put the DJ Console in non-Asio mode and then launch Virtual DJ.
- In the config options inside Virtual DJ, select the "sound cards" tab and find the "Advanced Config" option
- Click on the advanced config button and make sure that "none" is selected everywhere. Press OK twice to close the config panel
- Close Virtual DJ
- Switch the DJ Console in ASIO mode
- Open Virtual DJ, then open the Config cpl
- Press the "advanced config" button
- Select "Hercules DJ Console ASIO" for the left desk, right desc and headphones. Select the proper channels of your choice.
- Virtual DJ is working in ASIO mode with the DJ Console. Even if you close Virtual DJ and relaunch it, it will still work...
We will see with the Virtual DJ team what can be done to make it simpler.
Thanks
The Hercules Dev team
Douleuoume panw se auto to problhma gia na luthei.
geposted Mon 28 Mar 05 @ 6:38 pm
dimitri : les na pao sto naka apo opoy to phra na mou to kanoun fix up.
geposted Mon 28 Mar 05 @ 6:57 pm
EUXARISTO DIMITRI KAI ALLA PAIDIA GIA THN BOHTHIA OLA EINAI ENTAKSI THA SAS PO GIA ENA PARTY STON ISTIOPLOIKO OMILO STO MIKROLIMANO OPOU MPOROUME NA GNORISTOUME THA PAIKSO MOUSIKI ME TO VDJ 2.06 KAI THN HERCULES CONSOLA THA SAS EXO NEA SYNTOMA KAI FOTO APO STUDIO. GEIA SAS GIA THN ORA
geposted Mon 28 Mar 05 @ 8:05 pm
nakas mpa emporio mono kanei
afou to xrhsimopoieis epagkelmatika tha se sumbouleua na deis kai to xp10
geposted Mon 28 Mar 05 @ 8:12 pm
41%
