If I type in a search in the search bar, most songs come up with an error. but if I look in my finder and discover where to locate the file on my hard drive, then navigate there in Cue the file will play...
How do I fix this?
How do I fix this?
geposted Fri 25 Jan 08 @ 10:55 pm
Did you recently move these files? If you did, you need to update the database, these options are a browser tab of the config screen. Select the "clean" option.
geposted Sat 26 Jan 08 @ 12:46 am
Thanks
geposted Sat 26 Jan 08 @ 8:04 am
