Forum: Old versions
Topic: external mixer setup?
im new to virtualdj v5.. was wondering if its possible to hook up to external mixer? im using a SB Live 5.1 (yes I know crappy) just thought it may work?? is it possible to use the mixer, and cue? if so how can i set this up.. i see the external mixer option in config preferences, but i can only get 1 channel to play out on the mixer... help please, thanks!
geposted Thu 31 Jan 08 @ 1:33 am
You need a sound card that has two channels for this to work well. Like the Maya 44 or even Hercules DJ Console.
The other way is to have two sound cards. Set the sound config to dual cards and let the output from each card go to each channel on the mixer.
geposted Sat 02 Feb 08 @ 9:59 pm
