Forum: Old versions
Topic: Help me to change my Sound Card Please!!!
Hello!
Well, I just wanted to ask you:
I intend to change my sound card "Maya 44USB" because apparently it works very badly on Mac OS 10.5 Leopard! (Signal "Time Codes" half .... etc for example) with version 05beta3
So my question is: What do you recommend for another sound card, quality mode with ASIO for TCV and Mac OS 10.5 if possible?
Thank you in advance for your advice!
geposted Fri 01 Feb 08 @ 6:38 am
sbangsPRO InfinityMember since 2004
Full V5 is out very soon and will adress issues with timecode.
You need to make an agrigate device which is explained in the topic manual adin for mac.
geposted Fri 01 Feb 08 @ 6:25 pm
