Forum: Old versions
Topic: database "fix" "clean"
I tried running this option and nothing ran...i'm doing this because there are files that are popping up that are on different drives that aren't present.
am i in the right place and is this feature currently working?
geposted Fri 01 Feb 08 @ 2:55 pm
Ya, I ran this option too and it didn't seem to do anything.
geposted Fri 01 Feb 08 @ 5:08 pm
still seems to not be working in latest release.
geposted Mon 04 Feb 08 @ 3:44 pm
sbangsPRO InfinityMember since 2004
i will investigate this further for you.
geposted Mon 04 Feb 08 @ 5:56 pm
k_onePRO InfinityMember since 2006
I've mentioned this several times Simon, and it really doesn't do anything on the MAC version...yet that is.
I'm hoping it will be implemented in later versions ;)
geposted Tue 05 Feb 08 @ 5:30 am
anything yet sky?...this is getting annoying...i know i can just delete then start over but that will also erase all my bpms. also, when i make autoplay list, I can't tell
which songs it will play and which ones it will skip because it can't find it.
geposted Thu 07 Feb 08 @ 12:39 am
It will need to be addressed in a quick update the dev team are in america with numark this week so a fix hopefully can be investigated at the weekend.
geposted Thu 07 Feb 08 @ 11:44 am
oh ok..so this is something that you duplicated then and not just me...ok...thanks for the reply.
geposted Thu 07 Feb 08 @ 3:38 pm
