Hello!
I just bought the sound card "Edirol FA-66" to replace "Maya 44USB";
I use the version 5beta3 "Virtualdj", on a "Macbook Mac Os X 10.5 Leopard"
By following the advice in the manual Mac, I still can not make my "TCV;(Using Aggregated Device)
Is it a software problem? Or is it that I forgot to do something?
I used "Virtualdj" for 4 years on "PC", and I never had any problem
Can you help me to set about "Mac OSX" please?
geposted Sun 03 Feb 08 @ 8:28 am
Go to Applications > Utilities and run audio and midi setup.app
Now in this example i have used an mk2 but its the same method for the maya 44 usb and similar cards.
Then go to Audio Setup and choose these :
and then open time-code options , choose cd or vinyl as appropriate and press auto configure and it should now give you 100%
if not try to set auto-latency on preferences.
geposted Sat 09 Feb 08 @ 7:22 am
