I downloaded 5.7 and installed it however I noticed that it was like re installing it for the very first time and not installing an update, should I of uninstalled the old one first?
Plus I cant find anywere on the forum were it states what has been done.
geposted Tue 05 Feb 08 @ 1:59 pm
It will install over , the previous version , but it is better to uninstall as it means you have all the latest versions of the files needed for VDJ to run ,
just remember to back up the database files in my documents.
geposted Tue 05 Feb 08 @ 2:14 pm
If I go to programs and features in vista and remove it from there after Iv backed up my database is this sufficiant to remove everything so that I can do a better install of 5.7?
geposted Tue 05 Feb 08 @ 3:09 pm
Yes that would be fine , its not critical to make it work but its just good practice to do a clean install.
geposted Tue 05 Feb 08 @ 3:22 pm
Thanks a lot.
geposted Tue 05 Feb 08 @ 4:06 pm
Don't you still need to go into REGEDIT and delete VDJ
from the registry also?
geposted Wed 06 Feb 08 @ 11:01 am
Thats only necessary if there is a corrupted install its not generally needed also now the info tab in config has the option to Reset all settings to factory defaults which will repair corrupted installs.
geposted Wed 06 Feb 08 @ 1:02 pm
Thanks.
geposted Wed 06 Feb 08 @ 5:53 pm
