Hello everybody!
Virtual DJ is very nice program but not the only one :)
Anyway, i like very much plugin named tk filter. I wonder if i can use it with any other software (cubase sx for example)? Or can you maybe help me to find a similar plug-in that will be work thru vst or dx?
geposted Tue 12 Feb 08 @ 2:33 pm
TS Filter is native VDJ code, sorry, so cant be used in other apps..
But there are SOOOOO many free VSTs filter effects though ;) that you can use in VDJ and other apps..
Here is a start:
http://www.freesoundeditor.com/incageneng.html?VSTFiltereng.htm~main
http://www.audiomastermind.com/browse-filters-5887003-1.html
http://www.camelaudio.com/camelcrusher.php
Here is a start:
geposted Tue 12 Feb 08 @ 2:36 pm
By the way... by "similar" i mean the way i control it and not the functionality.
geposted Tue 12 Feb 08 @ 2:37 pm
There are LOTS of similar control interfaces too ;)
Just gotta look at the free VST filter pages
Here is one
http://www.sonicspot.com/cyanide/cyanide.html
geposted Tue 12 Feb 08 @ 2:42 pm
im using some of the vst plugins now and I like the sound the only problem I have is that the plugin stops when the music stops. I mean if I press the stop/pause button the plugin stops. :(
geposted Wed 19 Mar 08 @ 11:53 pm
