i need a good souncrad to get with my laptop..
i want the echo indigo dj.. is it a usb soundcard or a pcmcia one??
i dont think i have a free pcmcia slot so what is a good soundcard to get??
geposted Fri 03 Dec 04 @ 2:18 am
          maya 44 usb - 2 line in x 2 line out with Asio drivers
    geposted Fri 03 Dec 04 @ 2:55 am
          echo indigo DJ is a PCMCIA (cardbus) with 4 line outs
http://www.echoaudio.com/Products/CardBus/IndigoDJ/index.php
geposted Fri 03 Dec 04 @ 3:31 am
          depends on what your use is...
for dj practice and learning, even small gigs:
- Hercules usb Dj console (dual soundcard AND controller for VDJ)
for non-asio use :
- most usb soundcards will do... if not to concerned about having the state-of-the-art
for pro dj-ing without timecode
- xp10 with build in single soundcard
for asio-use (most important if you are gonna use timecode vinyl)
- maya 44
just a few thougts ;)
for non-asio use :
- maya 44
geposted Fri 03 Dec 04 @ 2:02 pm
          thanks
just cancelled my order of echo..going in for the maya 44
cheers
cheers
geposted Sun 05 Dec 04 @ 4:17 am
