Recently I upgrade from the console ed. I'm using the video skin.
Now I'm noticing the righ-clicking the Sync button does no longer activate the beatlock function, but does start the track synced instead.
How can I get back the beatlock function when r-click the sync button?
Are such changes done with a mapper or changing the xml file of the skin?
btw. I find it change that r-click has this standard function now, do most DJ's use it like this then? I don't find it very usefull, I personally prefer the beatlock function.
geposted Wed 20 Feb 08 @ 9:34 am
U can still activates the beatlock via keyboard shortcut by pressing B enabling n disabling the function;)
geposted Wed 20 Feb 08 @ 11:06 am
Yes I know the B key trick, but I still looking to chnage the skin some how, but don't how to start with it or if it's even possible.
geposted Fri 22 Feb 08 @ 2:30 am
Find in the XML for the skin these 2 lines -
Change to --
<button action="sync" chan="1" rightclick="auto">
<button action="sync" chan="2" rightclick="auto">
Change to --
<button action="beatlock" chan="1" rightclick="auto">
<button action="beatlock" chan="2" rightclick="auto">
geposted Fri 22 Feb 08 @ 5:19 am
Yes that did the trick, wasn't even so hard to do. I repacked the modified xml back into the zip.
Is there more info available about this xml? There seems a lot possible with these.
geposted Sun 24 Feb 08 @ 3:35 pm
