Some of my mps's have the title missing so I go into file info and enter it there and it's ok however unless i save the data base for my new computer im knackerd right?
geposted Wed 20 Feb 08 @ 2:24 pm
How many drives do you use ?
If you are using only the C: Drive to store your Music, then you only need to copy the file in the My Documents -> VirtualDJ folder to the same location on your new computer.
If you use other drives internal (D: partition) then same thing from the Root of that drive - copy the file to your D: partition on the new computer (provided that you have one there as well)
If you use an external drive(s) then there is no sweat as the DBs are stored on those respective drives in the Root and the data will be there when you plug it into the new computer.
geposted Wed 20 Feb 08 @ 4:35 pm
