with the native support from vdj, i notice with the use of the function key is limited to "hot cues" only, wish there was an option or a how to change the function to play my sampler instead. with a custom midi mapper, the look is not the same as the native support. can anyone provide a mapper that will function the same way as native support with the sampler capabiliity using the function keys
geposted Thu 21 Feb 08 @ 1:17 am
JPBoggis is working on a fully featured mapper, and I've written a more limited one as an interim solution for myself. Unfortunately to use these mappers you will need to be a Pro user anyway.
Regards,
Scott
Regards,
Scott
geposted Thu 21 Feb 08 @ 7:42 am
@ scott: which functions did you map differently?
@all: Have a party this weekend and I am uncertain if native support for HC4500 ( firmware 1005 with VDJ5rev6/7 and XP ) is stable enough for it, or if I should stay with my midi-mapping.Whats your feedback?
Regards
DJ M-2
Regards
DJ M-2
geposted Fri 22 Feb 08 @ 5:48 am
How can I get the mapper, how do I install it
would the pitch bend work? or the pitch range
how about the fx selection, loop adjustmet scenario
THX
THX
geposted Fri 22 Feb 08 @ 12:31 pm
Regards
DJ M-2
Regards
DJ M-2
If you read the feedback from people who have updated their HC 4500 with the current firmware and using version 5.7 of VDJ it's been very positve. The mapper would still somewhat be based on the Denon update.
geposted Fri 22 Feb 08 @ 1:59 pm
THX
THX
The mapper is not available yet, but yes, you can do all of the above using it and more.
geposted Sat 23 Feb 08 @ 1:54 pm
Can anyone please tell me how I can use the Pitch bend - and + buttons, using MIDI. I have tried to put a code in for that, but have been unsuccessful. Your help would be greatly appreciated. Thank you in advance.
geposted Sun 24 Feb 08 @ 9:41 pm
try using this midi mapper http://rapidshare.com/files/60347690/DN-HC4500.xml
geposted Mon 25 Feb 08 @ 11:10 am
Any word on jboggis' new mapper?
geposted Tue 04 Mar 08 @ 11:59 am
