When ever I hit the play button. nothing happens.. the songs wont play, i know that the songs arent currupt because they load fine with all the cue points. i tried un installin restarting my comp re booting then re-installing but that did seen to work.. did it about three times.. i teid diff skin, what could it be?? please help im djing in two days and i need this problem fixed or ill be out 500 bucks
geposted Thu 21 Feb 08 @ 1:51 am
Try change the performance slider to fastest n select auto for latency.. does that help?
geposted Thu 21 Feb 08 @ 2:25 am
Hello Vgarcia
What is your computers specification and what sound-card do you use?
What format are your music files and where did you source them ?
geposted Thu 21 Feb 08 @ 5:03 am
If your sound card is not properly assigned, the program will not play the tracks
Please look at sound settings and be sure you have the right card connected and properly assigned.
geposted Thu 21 Feb 08 @ 12:29 pm
