Forum: Old versions
Topic: external sound cards and virtual dj
i just purchased an external sound card(creatvie sound blaster) to use with virtual dj because my laptop only had one sound card so i couldnt use headphones but even witht his installed i can only hear the music either through the headphones or the computer,one or the other not both,is there anyway i can configure this so i can listen to the track im geting ready to mix in the headphones with the song playing through the computer,i am running vista windows if that helps, any help would be greatly appreciated
geposted Sat 23 Feb 08 @ 12:34 pm
In sound setup (under config), you should be able to set up for headphones with two cards; under output, choose headphones, under soundcards, multiple soundcards, set one for master and the other for headphones.
geposted Sat 23 Feb 08 @ 8:37 pm
