OK MAC users, I need your help once again. Does anybody use VDJ with numark ICDX and hooked up to a MAC? My question is how do you run your outputs from a macbook??? Is it possible to run three outputs from a MAC??? HOW???? I might be converting, and I need to be 100 % sure i can use my stuff with a MAC... Thanks a lot!
DJ TURIZ
(SAN DIEGO, CA {USA})
DJ TURIZ
geposted Thu 28 Feb 08 @ 6:32 am
Hi there the ICDX cannot be used as a soundcard for your pc it is a HID controler for CUE/VV/VDJ , so you will require an aditional usb sound interface ie Numark DJ/io or a similar usb card.
geposted Thu 28 Feb 08 @ 7:35 am
