Forum: Old versions
Topic: CDJ-400 ASIO driver (PC) - Page: 1
geposted Mon 03 Mar 08 @ 8:32 am
ciocePRO InfinityMember since 2004
geposted Mon 03 Mar 08 @ 1:11 pm
RonnieBPRO InfinityMember since 2008
Nice, now we just have to wait for native support to get the fullest out of VDJ :)
geposted Tue 04 Mar 08 @ 1:54 am
freppaPRO InfinityMember since 2002
Thanx for the links..
Well lets hope that there will be a perfect mapping (like iCdx) soon and all configurations problems will be solved :-)
/Fredrik
geposted Tue 04 Mar 08 @ 12:39 pm
sorenHome userMember since 2004
Can someone please help me?
I downloaded the driver and installed it.
Than I connected the cdj-400's.
My Remote Controle is:
- general midi
My Sound Setup is:
- inputs: timecodes
- outputs: external mixer
- soundcards: asio drivers
- asio driver: pioneer cdj400 asio
- input channels: chan 1&2 left deck / chan 3&4 right deck
- output channels: left deck chan 1&2 / right deck chan 3&4
Is that owkay? Because VDJ says that there are to many channels..
thank you...
geposted Tue 23 Dec 08 @ 11:56 am
cstollPRO InfinityMember since 2004
The CDJ-400 are output only .... you can not use them with timecode.
geposted Tue 23 Dec 08 @ 12:09 pm
so i've got the cdj 400 and want to use the virtual dj along wit it....
now is there a specific version of virtual dj i need to have to be able to use my player on the vdj???
so far my sound is setup as
-INPUT: none
-OUTPUT: external mixer
-SOUND CARD: 2cards
-SOUND (1): cdj 400
-SOUND (2): cdj 400
the part i dont get is how to set the "REMOTE CONTROL" features...
i need help wit that please!!!
i can control the sound wit the mixer when i play a song off my laptop, but the cdj seem to jus sit there...
hope im makin some sense...
geposted Sat 16 May 09 @ 2:32 am
DJJAMMPRO InfinityMember since 2005
NO NO NO..
geposted Mon 18 May 09 @ 2:24 am
Last I checked VDJ has native CDJ400 support.. No need for timecode, just plugin USB and set the CDJ to PC mode and select the CDJ400 as input device in VDJ..
Again last I checked..
geposted Tue 19 May 09 @ 2:16 pm
If you are experiencing any issues relating to your ASIO SOUND DRIVER when opening your Virtual DJ 6.0, go to his site and download the software to fix the issue: http://www.asio4all.com/
As soon as you download, open up your virtual DJ and everything will operate normally without any ASIO ERRORS!!!!!
geposted Thu 02 Sep 10 @ 1:43 am
geposted Thu 02 Sep 10 @ 1:46 am
djklavxHome userMember since 2011
hola:
miren acavo de comprar un denon hc 5000 y no puedo hacer que funcione con virtual si me pueden ayudar seria muy util
...muchas gracias y asta luego.
geposted Tue 08 Mar 11 @ 7:43 pm
Sorry, this forum is for English language messages only.
Please either re-post your message in English or post it in the correct language forum http://www.virtualdj.com/forums/index.html
Also, if your message does not have anything to do with Pioneer CDJ-400 ASIO drivers (You mention HC5000, so this is probably the case), then please open your own new topic rather than hijacking an existing thread that is unrelated to your question.
geposted Wed 09 Mar 11 @ 4:23 am
Is this also campstible with Mac OS X?
geposted Sun 26 Jun 11 @ 5:00 pm
KOSTA69Home userMember since 2012
καλησπερα , ψαχνω να βρω ενα LINK για τους drivers PIONEER CDJ 450 , μπορει καποιος να με βοηθησει ? ευχαριστω
geposted Fri 09 Aug 13 @ 11:31 am
geposted Fri 09 Aug 13 @ 11:38 am
nobblePRO InfinityMember since 2013
The problem I have is that both cdj-400 appear in channel 1 (display and signal), and I cant´make them be in channels 1&2
geposted Wed 18 Sep 13 @ 11:07 am
geposted Wed 18 Sep 13 @ 11:32 am
plz send me the link to use nxaudio cdj700s asio driver
geposted Mon 20 Jan 14 @ 2:13 am
Your post is not related to the subject of this thread.
If the CDJ700 has an ASIO driver, it will be supplied with the product. If there was no driver supplied then a driver is not required.
If you are sure that the product requires an ASIO driver (if it is mentioned in the product manual) then you need to contact the manufacturer.
geposted Mon 20 Jan 14 @ 5:27 am
91%
