Is there a way I can print my keyboard shortcuts out? Or is there a list of the standard shortcuts in VDJ or VDJ2 that I can print?
Some help would be appreciated.
Thanks.
Thanks.
geposted Sun 12 Dec 04 @ 12:29 pm
You can use a graph program with a screen capture feature and use it with a windowed option. This way you make a capture of each part displayed on the config window and then you print each part.
You can also open the .xml file and remove the unexpected features but that's boring.
It would be cool to have a print feature in the next releases.
geposted Sun 12 Dec 04 @ 12:58 pm
^ Put screen capturing it would be fking annoyin to print... Anyone know if there's a list of standard combo's online? Or do they know a good way in which I can change the .xml file into someting I can look stuff up quickly and so that it's clear (like in the keyboard settings)? Cuz that way I could just 'pint the XML file'.
geposted Mon 13 Dec 04 @ 1:10 pm
