Uscito nuovo plugin Video per la visualizzazione delle foto, ATTENZIONE è una beta
SBDJ SlideShow (Beta 1)
Descrizione:
Effect
A new SlideShow plugin that keeps images aspect ratio correct (according to the output screen resolution).
< This version is an initial beta, so test at your own risk.
If you have problems, please make sure you have at least Directx 9 November 2007 updates installed.
Scratch Worx v1.0
Descrizione:
3-In-1 Transition
Chrono Cut:
Scratch Cut:
Line Fader:
Assign your upfaders to video_trans_param 1 and 2 and your crossfader to video crossfader.
Scratch Cut:
Works exactly the same way as the scratch transition.
Line Fader:
Works by fading between videos using your upfaders.
Chrono Cut:
Works by evaluating the speed of your turntable and cutting back to the other video if it slows down below a certain point (which is editable in the transition FX tab: chrono cut sensitivity slider. Push completely to the left to switch off).
Revisione:
/! If the plugin doesn't work on your computer, please download and install the microsoft update available here
Download -> http://www.virtualdj.com/addons/view.html?type=video%20effect
Descrizione:
Effect
Scratch Worx v1.0
Descrizione:
3-In-1 Transition
Chrono Cut:
Scratch Cut:
Line Fader:
Scratch Cut:
Line Fader:
Chrono Cut:
Revisione:
geposted Thu 06 Mar 08 @ 1:40 am
Disponibile già da un po' di tempo un bel pacchetto di transizioni video per MAC
Descrizione:
In this zip file, you will find the following video transitions for the MAC version of VirtualDJ:
* Slide3D
* Spiral
* SizeFall
* Curtain
* LightFall
* Rhombus
scaricare il file .zip (download mac) e scompattarlo quindi copiare la cartella della transizione "xxx.bundle" in:
/users/"nome utente"/documents/VirtualDJ/plugins/VideoTransition
Link diretto al download -> http://www.virtualdj.com/addons/download.html?addon_id=4146
Descrizione:
* Slide3D
* Spiral
* SizeFall
* Curtain
* LightFall
* Rhombus
geposted Tue 11 Mar 08 @ 3:30 am
Aggiornamento per il plugin per la visualizzazione delle foto SBDJ SlideShow v1.01
Link agli effetti video :-> http://www.virtualdj.com/addons/view.html?type=video%20effect
Bye Joe
Bye Joe
geposted Sun 27 Apr 08 @ 10:01 am
Salve a tutti.Finalmente con questo plug-in(SBDJ SlideShow)le slides si aprono nel formato originale.
L'unico problema che ho riscontrato è che,se nel frattempo proietto videoclips,in sottofondo si vede parte della videoclip che stò "suonando".
Saluti.
Saluti.
geposted Tue 29 Apr 08 @ 12:38 am
ciao guarda devi mettere la trasparenza dell'effetto al minimo cosi non vedi sotto la parte della videoclip. ciaoooooo
geposted Tue 29 Apr 08 @ 2:31 am
@ gianlucadj:scusa ma non riesco a trovare l'effetto trasparenza. Nel pannello del plug-in ci sono solo il ritardo e la risoluzione + i pulsanti slideshow,
transizione ed enlarge small pictures o mi sono perso qualcosa ?(devo forse attivare un altro plug-in?)
Ciao e grazie :)
Ciao e grazie :)
geposted Tue 29 Apr 08 @ 4:11 pm
Infatti questo effetto non è dotato della slide per impostare la trasparenza, forse gianlucadj l'ha provato un attimino in fretta, nel weekend se ho tempo faccio alcune prove e vi so dire.
geposted Wed 30 Apr 08 @ 1:43 am
