I have a MacBook Pro 2.6 ghz and running Virtual DJ Pro. My set up is simple as i come out of the headphone jack into my mixer however some of my music was recorded in mono so I'm fairly certain this is what is causing my delimma however what can i do to fix it without re-recording my music. Also my logic for recording in mono is if i lost a speaker i wouldn't have this issue in the first place of having a song with lyrics without music or vice versa. What is really weird is that when I daisy change my speakers together i get the full range of music...what gives????
geposted Mon 10 Mar 08 @ 6:39 pm
you recorded in mono so your ouput is gonna be mono (one channel) ur gonna need to re-record in stereo. as far as you daisy chaining...ur just duplicating
mono output...when you daisy chain, your coming off of one channel. You can try using "mono separated" in your sound config to see if that works for you.
You will probably need to purchase a special adapter cord.
geposted Mon 10 Mar 08 @ 8:29 pm
