Hi,
Just got a mac book pro today. I also own a U46DJ and had the error in the sound driver of coreaudio before I saw how to create an aggregate in the audio panel.
After I created an aggregate when I select it in Virtual DJ I can see the CPU bar increasing and VDJ becomes unresponsive any idea why?
Can you also explain to me why we have to create aggregates?
Is this something that will be fixed in 5.1?
Thanks a lot for your time.
geposted Sat 15 Mar 08 @ 7:12 pm
Check my blog for a guide to setup aggregates.
hopefully solved in 5.1 yes.
geposted Sat 15 Mar 08 @ 7:56 pm
as I said I've added the aggregates alright but it's when I select them in VDJ that the app hangs.
cheers
cheers
geposted Sat 15 Mar 08 @ 8:49 pm
Try to select quicktime audio as your mp3 decoder.
Config > Codecs
Mp3 : Quicktime Audio
Config > Codecs
geposted Sat 15 Mar 08 @ 8:51 pm
thanks for your help but that doesn't do it. I 'm not even playing anything, it crashes at soon as I select aggregate device. I can see the CPU bar filling up in VDJ. Check it out:
geposted Sun 16 Mar 08 @ 4:34 am
Hi could you please pm me the text in the most recent VDJ crash log its saved in Users/yourname/libary/logs/crashreporter
geposted Sun 16 Mar 08 @ 6:54 am
Did you guys have any luck with this? I'm getting the same error.
geposted Thu 27 Mar 08 @ 4:46 am
