Forum: Old versions
Topic: Will this set up work? (MK2 and Timecode)
FaultPRO InfinityMember since 2007
Ok, first off i know i have to upgrade my VDJ software. But heres what im planning on:
2 timecoded vinyls
2 Numark T200 turntables
The 2 Numarks plugged into my Hercules MK2 via RCA-RCA
Hercules MK2 to Laptop via USB
Will this setup work/any suggestions to make it better?
geposted Fri 21 Mar 08 @ 1:13 pm
sbangsPRO InfinityMember since 2004
You should take a look at our TT500 range they feature the same high quality direct drive motors as our flagship TTX range but do not have the digital displays which are not needed as i assume you want to time code.
You may also want to look at Virtual Vinyl , which is a package of a high quality sound card , 2 vinyls and the pro edition of the software or an alternative soundcard :
www.virtualdj.com/products/hardware.html
The mk2 is a mid range sound card and might not give you the results you want.
geposted Fri 21 Mar 08 @ 2:55 pm
